Ana içeriğe geç
Insignia Flex 11.6 Motherboard Replacement
Neye ihtiyacın var
  1. Insignia Flex 11.6 Motherboard Replacement, Power Removal: adım 1, 3 resimden 1. Insignia Flex 11.6 Motherboard Replacement, Power Removal: adım 1, 3 resimden 2. Insignia Flex 11.6 Motherboard Replacement, Power Removal: adım 1, 3 resimden 3.
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Motherboard Replacement: adım 2, 2 resimden 1. Insignia Flex 11.6 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. How to Remove a Stripped Screw
  3. Insignia Flex 11.6 Motherboard Replacement: adım 3, 3 resimden 1. Insignia Flex 11.6 Motherboard Replacement: adım 3, 3 resimden 2. Insignia Flex 11.6 Motherboard Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Motherboard Replacement: adım 4, 3 resimden 1. Insignia Flex 11.6 Motherboard Replacement: adım 4, 3 resimden 2. Insignia Flex 11.6 Motherboard Replacement: adım 4, 3 resimden 3.
    Satın Al
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Unplug the 2 speaker's connection from the motherboard.
  6. Insignia Flex 11.6 Motherboard Replacement: adım 6, 2 resimden 1. Insignia Flex 11.6 Motherboard Replacement: adım 6, 2 resimden 2.
    • Peel the yellow tape off from on top of the electrical connectors.
  7. Insignia Flex 11.6 Motherboard Replacement: adım 7, 2 resimden 1. Insignia Flex 11.6 Motherboard Replacement: adım 7, 2 resimden 2.
    Satın Al
    • Flip up the black cover pieces to expose the 3 electrical connectors.
    • Remove 3 electrical connectors by gently pulling back on them with some tweezers.
  8. Insignia Flex 11.6 Motherboard Replacement: adım 8, 3 resimden 1. Insignia Flex 11.6 Motherboard Replacement: adım 8, 3 resimden 2. Insignia Flex 11.6 Motherboard Replacement: adım 8, 3 resimden 3.
    • Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
    • Remove the black camera connector by gently prying on it until it unhooks.
  9. Insignia Flex 11.6 Motherboard Replacement: adım 9, 2 resimden 1. Insignia Flex 11.6 Motherboard Replacement: adım 9, 2 resimden 2.
    • Using tweezers, remove the microphone from the the plastic cover.
  10. Insignia Flex 11.6 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
    • Motherboard pops out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
This looks great. Can you provide more detail on Step 3 (opening the case?) Are there locking tabs that I need to worry about breaking? And if so, how many? Does the cover simply snap back into place?
I need to open my unit simply to disconnect the power to clear the BIOS. I stupidly disabled my USB ports and there is no way to navigate the BIOS without the (USB) keyboard (how freaking dumb is that!)
Mugsys RapSheet - Yanıt
Very nicely done. Do you suppose that the SSD can be upgraded to something larger?
Curtiss Riedel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 2,466
