Ana içeriğe geç
Insignia Flex 11.6 Screen Replacement
Neye ihtiyacın var
  1. Insignia Flex 11.6 Screen Replacement, Power Removal: adım 1, 3 resimden 1. Insignia Flex 11.6 Screen Replacement, Power Removal: adım 1, 3 resimden 2. Insignia Flex 11.6 Screen Replacement, Power Removal: adım 1, 3 resimden 3.
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Screen Replacement: adım 2, 2 resimden 1. Insignia Flex 11.6 Screen Replacement: adım 2, 2 resimden 2.
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. How to Remove a Stripped Screw
  3. Insignia Flex 11.6 Screen Replacement: adım 3, 3 resimden 1. Insignia Flex 11.6 Screen Replacement: adım 3, 3 resimden 2. Insignia Flex 11.6 Screen Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Screen Replacement: adım 4, 3 resimden 1. Insignia Flex 11.6 Screen Replacement: adım 4, 3 resimden 2. Insignia Flex 11.6 Screen Replacement: adım 4, 3 resimden 3.
    Satın Al
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Screen Replacement, Motherboard: adım 5, 1 resimden 1.
    • Unplug the 2 speaker's connection from the motherboard.
  6. Insignia Flex 11.6 Screen Replacement: adım 6, 2 resimden 1. Insignia Flex 11.6 Screen Replacement: adım 6, 2 resimden 2.
    • Peel the yellow tape off from on top of the electrical connectors.
  7. Insignia Flex 11.6 Screen Replacement: adım 7, 2 resimden 1. Insignia Flex 11.6 Screen Replacement: adım 7, 2 resimden 2.
    Satın Al
    • Flip up the black cover pieces to expose the 3 electrical connectors.
    • Remove 3 electrical connectors by gently pulling back on them with some tweezers.
  8. Insignia Flex 11.6 Screen Replacement: adım 8, 3 resimden 1. Insignia Flex 11.6 Screen Replacement: adım 8, 3 resimden 2. Insignia Flex 11.6 Screen Replacement: adım 8, 3 resimden 3.
    • Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
    • Remove the black camera connector by gently prying on it until it unhooks.
  9. Insignia Flex 11.6 Screen Replacement: adım 9, 2 resimden 1. Insignia Flex 11.6 Screen Replacement: adım 9, 2 resimden 2.
    • Using tweezers, remove the microphone from the the plastic cover.
  10. Insignia Flex 11.6 Screen Replacement: adım 10, 1 resimden 1.
    • Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
    • Motherboard pops out.
  11. Insignia Flex 11.6 Screen Replacement, Screen: adım 11, 3 resimden 1. Insignia Flex 11.6 Screen Replacement, Screen: adım 11, 3 resimden 2. Insignia Flex 11.6 Screen Replacement, Screen: adım 11, 3 resimden 3.
    • Remove battery by prying off with card.
  12. Insignia Flex 11.6 Screen Replacement: adım 12, 2 resimden 1. Insignia Flex 11.6 Screen Replacement: adım 12, 2 resimden 2.
    • Peel back the copper color electrical connector with blue opening tool.
  13. Insignia Flex 11.6 Screen Replacement: adım 13, 1 resimden 1.
    • Remove 12 - 4.15mm J000 Phillips screws from the metal bracket.
    • Bracket will then come off.
  14. Insignia Flex 11.6 Screen Replacement: adım 14, 1 resimden 1.
    • Remove 1 - 3.4 mm J000 Phillips screw from metal plate bracket.
  15. Insignia Flex 11.6 Screen Replacement: adım 15, 2 resimden 1. Insignia Flex 11.6 Screen Replacement: adım 15, 2 resimden 2.
    • Remove screen from case by prying with a card.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
6 Yorum
The Flex 11.6" Model# NS-P11W7100 DOEST HAVE THOSE SCREWS RIGHT THERE!!!!!
Charles Kinnison - Yanıt
yeah, thats the one I have. its quite a bit different. the speaker wires are soldered, too…
Joshua Francis -
mine doesn’t look like that…
Joshua Francis - Yanıt
where can i get a new screen to buy?
florence sefaa - Yanıt
Do you sell the insignia ns-p11w7100 tablet 11.6 inches screen? I need on to fix my broken part.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 4,469
