Ana içeriğe geç
Insignia Flex 11.6 Speakers Replacement
Neye ihtiyacın var
  1. Insignia Flex 11.6 Speakers Replacement, Power Removal: adım 1, 3 resimden 1. Insignia Flex 11.6 Speakers Replacement, Power Removal: adım 1, 3 resimden 2. Insignia Flex 11.6 Speakers Replacement, Power Removal: adım 1, 3 resimden 3.
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Speakers Replacement: adım 2, 2 resimden 1. Insignia Flex 11.6 Speakers Replacement: adım 2, 2 resimden 2.
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. How to Remove a Stripped Screw
  3. Insignia Flex 11.6 Speakers Replacement: adım 3, 3 resimden 1. Insignia Flex 11.6 Speakers Replacement: adım 3, 3 resimden 2. Insignia Flex 11.6 Speakers Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Speakers Replacement: adım 4, 3 resimden 1. Insignia Flex 11.6 Speakers Replacement: adım 4, 3 resimden 2. Insignia Flex 11.6 Speakers Replacement: adım 4, 3 resimden 3.
    Satın Al
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Speakers Replacement, Speakers: adım 5, 1 resimden 1.
    Satın Al
    • Remove 2 electrical connectors that connects to the speaker using flat tweezers.
  6. Insignia Flex 11.6 Speakers Replacement: adım 6, 2 resimden 1. Insignia Flex 11.6 Speakers Replacement: adım 6, 2 resimden 2.
    • Remove 2 - 6 mm J000 Phillips screws from each of the speakers.
    • Speakers will pop out at this point.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 515
