Ana içeriğe geç
Insignia Flex 8 Battery Replacement
Neye ihtiyacın var
  1. Insignia Flex 8 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the power is off to avoid injury in the following steps.
    • Position the tablet so that the screen is face down.
    • The power button is located in the upper left hand corner.
    • Hold the power button for three seconds until the tablet powers down.
  2. Insignia Flex 8 Battery Replacement: adım 2, 2 resimden 1. Insignia Flex 8 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the back casing by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
    • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
    • Remove the back casing and set aside.
  3. Insignia Flex 8 Battery Replacement: adım 3, 1 resimden 1.
    • Peel back the tape from battery and case.
  4. Insignia Flex 8 Battery Replacement: adım 4, 1 resimden 1.
    • Slide the spudger beneath battery to pry away it away from the case. Work around the battery, prying up all edges to remove from glue.
    • Do not puncture or bend battery. This could cause battery to leak acid.
  5. Insignia Flex 8 Battery Replacement: adım 5, 1 resimden 1.
    • Desolder the black, yellow and red connections from circuit board. Desoldering Help
    • Keep the soldering tool away from other components on the circuit board.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Tyler Tyrrell
890 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 5-5, Panko Spring 2015 Colorado Springs, Team 5-5, Panko Spring 2015 üyesi
UCCS-PANKO-S15S5G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 9,096
