Ana içeriğe geç
Insignia NS-B4111 Speaker Replacement
Neye ihtiyacın var
  1. Insignia NS-B4111 Speaker Replacement, Battery: adım 1, 2 resimden 1. Insignia NS-B4111 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Speaker Replacement: adım 2, 2 resimden 1. Insignia NS-B4111 Speaker Replacement: adım 2, 2 resimden 2.
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Speaker Replacement, Casing: adım 3, 1 resimden 1.
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  4. Insignia NS-B4111 Speaker Replacement: adım 4, 2 resimden 1. Insignia NS-B4111 Speaker Replacement: adım 4, 2 resimden 2.
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  5. Insignia NS-B4111 Speaker Replacement, Antenna Base: adım 5, 2 resimden 1. Insignia NS-B4111 Speaker Replacement, Antenna Base: adım 5, 2 resimden 2.
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
  6. Insignia NS-B4111 Speaker Replacement, Motherboard: adım 6, 1 resimden 1.
    • Unscrew the four 12.5mm screws with the Phillips PH1 Screwdriver.
    • Unscrew the one 10mm long screw with the Phillips PH1 Screwdriver.
  7. Insignia NS-B4111 Speaker Replacement: adım 7, 1 resimden 1.
    • Orient the device so that the back is facing you.
    • Unplug the six pin male/female header from its socket on the motherboard. The wires on the header are these colors: burgundy, red, orange, yellow, green, and blue.
    • Use a tweezer if you find it hard to pull the header out with your fingers.
    • Gently pull out the ribbon cable from its socket on the motherboard.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the wires the wrong way may short circuit the board.
  8. Insignia NS-B4111 Speaker Replacement: adım 8, 1 resimden 1.
    • Rotate the device so that the front is facing you.
    • Unplug the four pin header from its socket on the motherboard. The wires on the header are these colors: brown, red, orange, and yellow.
    • Use a tweezer if you find it hard to pull this header out with your fingers.
    • Gently pull out the ribbon cable from its socket.
    • Pay attention to the orientation of the header and the ribbon cable. Replacing the base the wrong way may short circuit the board.
  9. Insignia NS-B4111 Speaker Replacement: adım 9, 1 resimden 1.
    • Pull out the two pin header from its socket on the motherboard. The wires on this header are black and white.
    • Use a tweezer if you find it hard to pull this cable out with your fingers.
  10. Insignia NS-B4111 Speaker Replacement, Front Panel: adım 10, 1 resimden 1.
    • Remove the four 8.5mm chrome screws from the front panel with the Phillips PH1 screwdriver.
  11. Insignia NS-B4111 Speaker Replacement: adım 11, 1 resimden 1.
    • Remove the front panel from the top casing.
  12. Insignia NS-B4111 Speaker Replacement, Speaker: adım 12, 1 resimden 1.
    • The following instructions will show you how to replace the left speaker. Follow the same instructions to replace the right speaker.
    • Use the blue opening tool to scrape the red adhesive off of the 12mm chrome screw.
  13. Insignia NS-B4111 Speaker Replacement: adım 13, 1 resimden 1.
    • Remove the 12mm chrome screw from the speaker with the Phillips PH1 screwdriver.
  14. Insignia NS-B4111 Speaker Replacement: adım 14, 1 resimden 1.
    • Remove any glue on the edges of the speaker.
  15. Insignia NS-B4111 Speaker Replacement: adım 15, 1 resimden 1.
    • Pop out the speaker from the front panel.
  16. Insignia NS-B4111 Speaker Replacement: adım 16, 2 resimden 1. Insignia NS-B4111 Speaker Replacement: adım 16, 2 resimden 2.
    • Unsolder the two wires at the given points. If you need help soldering, see this guide.
    • The speaker has two colored wires attached to the orange plate: one attached to the positive (+) end, and the other attached to the negative (-) end.
    • The left speaker (shown) has a yellow wire on the positive (+) end, and an orange wire on the negative (-) end.
    • The right speaker (not shown) has a brown wire on the positive (+) end, and a red wire on the negative (-) end.
Sonuç
Kristin Yoshioka
984 İtibar
9 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-5, Oliver Fall 2016 UC Davis, Team 1-5, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S1G5
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 527
