Ana içeriğe geç
Insignia NS-CLLT01 Button Replacement
Neye ihtiyacın var
  1. Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: adım 1, 2 resimden 1. Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: adım 1, 2 resimden 2.
    • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
  2. Insignia NS-CLLT01 Button Replacement: adım 2, 3 resimden 1. Insignia NS-CLLT01 Button Replacement: adım 2, 3 resimden 2. Insignia NS-CLLT01 Button Replacement: adım 2, 3 resimden 3.
    • On the bottom of the clock, use your fingernail to push the battery cover to the right.
    • Lift the battery cover up and to the right to reveal the batteries.
  3. Insignia NS-CLLT01 Button Replacement: adım 3, 1 resimden 1.
    • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Once the batteries are removed, close the cover.
  4. Insignia NS-CLLT01 Button Replacement: adım 4, 1 resimden 1.
    • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
    • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
  5. Insignia NS-CLLT01 Button Replacement: adım 5, 3 resimden 1. Insignia NS-CLLT01 Button Replacement: adım 5, 3 resimden 2. Insignia NS-CLLT01 Button Replacement: adım 5, 3 resimden 3.
    • Turn the clock back over.
    • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
  6. Insignia NS-CLLT01 Button Replacement, Button: adım 6, 1 resimden 1.
    • Using the Phillips #2 screwdriver, unscrew the seven 6mm Phillips screws on the circuit board that is attached to the top of the case.
  7. Insignia NS-CLLT01 Button Replacement: adım 7, 1 resimden 1.
    • Lift the circuit board from the device.
  8. Insignia NS-CLLT01 Button Replacement: adım 8, 2 resimden 1. Insignia NS-CLLT01 Button Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Detach the circuit board from the rest of the clock by gripping the sides of the white ribbon cable connector on the left-hand side of the board and pulling it straight off. You may need to use tweezers to grip the connector.
  9. Insignia NS-CLLT01 Button Replacement: adım 9, 3 resimden 1. Insignia NS-CLLT01 Button Replacement: adım 9, 3 resimden 2. Insignia NS-CLLT01 Button Replacement: adım 9, 3 resimden 3.
    • Use this soldering guide to remove and replace any buttons that were not working.
    • The buttons will be labeled on the top of the circuit board, and you will be working with the corresponding connections on the back.
Sonuç
Preston Jackson
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-9, Williams Fall 2015 Baylor, Team 6-9, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G9
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 317
