Ana içeriğe geç
Insignia NS-PLTPSP13 Speaker Cone Replacement
Neye ihtiyacın var
  1. Insignia NS-PLTPSP13 Speaker Cone Replacement, Insignia NS-PLTPSP13 Disassembly: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to lift the corner of the mesh until a gap is created.
  2. Insignia NS-PLTPSP13 Speaker Cone Replacement: adım 2, 2 resimden 1. Insignia NS-PLTPSP13 Speaker Cone Replacement: adım 2, 2 resimden 2.
    • Once there is a gap big enough, insert the metal spudger, and remove the tweezers.
  3. Insignia NS-PLTPSP13 Speaker Cone Replacement: adım 3, 3 resimden 1. Insignia NS-PLTPSP13 Speaker Cone Replacement: adım 3, 3 resimden 2. Insignia NS-PLTPSP13 Speaker Cone Replacement: adım 3, 3 resimden 3.
    • Now take the size J0 JIS screwdriver to remove the seven 5 mm screws on the plastic casing of the speaker.
    • Do not forget about the 5mm screw on the backside of the speaker, it may be covered by a white sticker, and it will prevent you from removing the plastic cover.
  4. Insignia NS-PLTPSP13 Speaker Cone Replacement: adım 4, 2 resimden 1. Insignia NS-PLTPSP13 Speaker Cone Replacement: adım 4, 2 resimden 2.
    • Once all seven 5mm screws are taken off use the metal spudger again to pry off the plastic casing from the speaker.
  5. Insignia NS-PLTPSP13 Speaker Cone Replacement: adım 5, 2 resimden 1. Insignia NS-PLTPSP13 Speaker Cone Replacement: adım 5, 2 resimden 2.
    • To further take apart the speaker, there are also two 5mm screws on the green circuit board which keep the speaker and circuit board attached. Unscrew these with the size J0 JIS screwdriver.
  6. Insignia NS-PLTPSP13 Speaker Cone Replacement, Speaker Cone: adım 6, 2 resimden 1. Insignia NS-PLTPSP13 Speaker Cone Replacement, Speaker Cone: adım 6, 2 resimden 2.
Sonuç
Colin Farragher
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Julie Spring 2017 UMass Dartmouth, Team S4-G2, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S4G2
5 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 23
Her zaman: 387
