Ana içeriğe geç
Installing Sewing Machine Bobbin
Neye ihtiyacın var
  1. Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: adım 1, 2 resimden 1. Installing Sewing Machine Bobbin, Installing Sewing Machine Bobbin: adım 1, 2 resimden 2.
    • Use your finger to open the bobbin door below the presser foot.
    FixBot'a Sor
    Yorum Ekle
  2. Installing Sewing Machine Bobbin: adım 2, 2 resimden 1. Installing Sewing Machine Bobbin: adım 2, 2 resimden 2.
    • Align the hole in the bobbin spindle over the peg in the bobbin case.
    • Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
    • Take the loose thread end and slide it through the slit on the side of the bobbin case.
    FixBot'a Sor
    Yorum Ekle
  3. Installing Sewing Machine Bobbin: adım 3, 2 resimden 1. Installing Sewing Machine Bobbin: adım 3, 2 resimden 2.
    • Slide the thread from the slit straight up along the groove and into the open hole on the bobbin case's side.
    FixBot'a Sor
    Yorum Ekle
  4. Installing Sewing Machine Bobbin: adım 4, 2 resimden 1. Installing Sewing Machine Bobbin: adım 4, 2 resimden 2.
    • Keeping the bobbin in place, turn the bobbin case so that the back is facing you.
    • Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
    FixBot'a Sor
    Yorum Ekle
  5. Installing Sewing Machine Bobbin: adım 5, 2 resimden 1. Installing Sewing Machine Bobbin: adım 5, 2 resimden 2.
    • Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot.
    • Align the metal arm on the bobbin case so that it sits in the slot in the machine.
    • Release the bobbin case.
    FixBot'a Sor
    Yorum Ekle
  6. Installing Sewing Machine Bobbin: adım 6, 2 resimden 1. Installing Sewing Machine Bobbin: adım 6, 2 resimden 2.
    • Close the door on the compartment below the presser foot.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
7 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
90.929 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.572 adet Kılavuz yazıldı
2Kılavuz Yorumları
Love it! Thank you for posting this as my wife has had to fix things on her sewing machine and it's good to have a reference other than Youtube where you can sit down and read it and make adjustments accordingly!
Alex - Yanıt Paylaş
Thank you for giving a good detailed answer that I had with the insertion of the bobbin on the sewing machine. I took a crash course today, came home and this evening decided to go through what I had learned and ran into a snag. I was able to overcome what was incorrect. Again, thanks a bunch 🧵
Felicia Jones - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 136
Son 30 gün: 330
Her zaman: 60,216
