Giriş
The Intex Quick-Fill air pump motor can burn out through normal use over time. The pump fans can also break if a foreign object makes it's way into the pump. If your Intex air pump (Quick-Fill AP636) has ceased to properly function and needs a motor replacement follow this guide to do so. Please make sure air pump is not plugged in before starting replacement.
Neye ihtiyacın var
Remove the air pump attachment by turning it counter clockwise to the unlocked position.
