Ana içeriğe geç
Iomega Z100S2 Motherboard Replacement
Neye ihtiyacın var
  1. Iomega Z100S2 Motherboard Replacement, Case: adım 1, 2 resimden 1. Iomega Z100S2 Motherboard Replacement, Case: adım 1, 2 resimden 2.
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Iomega Z100S2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Move down the same side and push in the plastic tab.
  3. Iomega Z100S2 Motherboard Replacement: adım 3, 1 resimden 1.
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Iomega Z100S2 Motherboard Replacement: adım 4, 2 resimden 1. Iomega Z100S2 Motherboard Replacement: adım 4, 2 resimden 2.
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Iomega Z100S2 Motherboard Replacement: adım 5, 2 resimden 1. Iomega Z100S2 Motherboard Replacement: adım 5, 2 resimden 2.
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
  6. Iomega Z100S2 Motherboard Replacement, Disk Reader: adım 6, 2 resimden 1. Iomega Z100S2 Motherboard Replacement, Disk Reader: adım 6, 2 resimden 2.
    • Unhook the two springs from the front plastic hooks.
    • The black side rails of the reader should easily slide forward and off.
  7. Iomega Z100S2 Motherboard Replacement: adım 7, 1 resimden 1.
    • There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
    • The tab does not come completely out, it only slides up slightly, so don't rip it out!
  8. Iomega Z100S2 Motherboard Replacement: adım 8, 2 resimden 1. Iomega Z100S2 Motherboard Replacement: adım 8, 2 resimden 2.
    • Grab the reader by its sides and gently pull it upward.
    • There are two wires still connected to the bottom of the reader that haven't been detached.
  9. Iomega Z100S2 Motherboard Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
  10. Iomega Z100S2 Motherboard Replacement: adım 10, 2 resimden 1. Iomega Z100S2 Motherboard Replacement: adım 10, 2 resimden 2.
    • Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
  11. Iomega Z100S2 Motherboard Replacement: adım 11, 1 resimden 1.
    • Lift the reader up and out from the device.
  12. Iomega Z100S2 Motherboard Replacement, Motherboard: adım 12, 2 resimden 1. Iomega Z100S2 Motherboard Replacement, Motherboard: adım 12, 2 resimden 2.
    • Use a T6 Torx Screwdriver to remove the 1.3 mm screw at the back of the motherboard.
  13. Iomega Z100S2 Motherboard Replacement: adım 13, 2 resimden 1. Iomega Z100S2 Motherboard Replacement: adım 13, 2 resimden 2.
    • Gently lift the motherboard and back case out from the bottom case.
Sonuç
Ezery Kennedy
288 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-53, Amido Fall 2010 Cal Poly, Team 7-53, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G53
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
how to fix the motherboard if booth leds stay lit when powering up?
ACIDGREEN TECHNO - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 3,533
