Neye ihtiyacın var
Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
Tilt the front case down until the pegs detach from the bottom of the case.
Lift up and outward.
Easy button and status light repair:
button and plastic piece both need just 2 tiny drops of super glue.
Use a T6 Torx Screwdriver to remove the 1.3 mm screw at the back of the motherboard.
1Rehber Yorum
how to fix the motherboard if booth leds stay lit when powering up?
