Ana içeriğe geç
JBL Charge 2 Plus Passive Radiators Replacement
Neye ihtiyacın var
  1. JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: adım 1, 2 resimden 1. JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: adım 1, 2 resimden 2.
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
    Test because my last comment disappeared.
    Debra Bainum - Yanıt
    You might ONLY need to remove the back grille. Read the comments on the next step.
    nus.czm - Yanıt
    Agree with comments above. All I had to do was remove the back grille to get to the plastic battery cover similar to comment above.
    Tim Pipkorn - Yanıt
    Danke, das hat mir weitergeholfen.
    Ganz herzlichen Dank
    Michael Pauw 04.08.2021
    Michael Pauw - Yanıt
  2. JBL Charge 2 Plus Passive Radiators Replacement: adım 2, 3 resimden 1. JBL Charge 2 Plus Passive Radiators Replacement: adım 2, 3 resimden 2. JBL Charge 2 Plus Passive Radiators Replacement: adım 2, 3 resimden 3.
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
    no 5mm screws going into the radiator on my device
    Norman Ingham - Yanıt
    I had the same issue. I managed to unplug the battery cable after removing the right front speaker
    Peter Karsten - Yanıt
    I have the charge 2 + and only needed to take off the back grill. Then removed 6 smaller screws from a black rectangular cover, which turns out to be the battery cover! Then unplugged the battery and removed it. Many less steps than described in the steps here. Note I did NOT have to remove either round end.
    I did the same thing! Everybody should read your comment before attempting this whole process described below.
    You ONLY have to remove the back grille, and you will see the battery cover. Unscrew the small philips screws from the battery cover, then the whole battery cover can be removed.
    nus.czm -
    The other comments are misleading. Yes, you can see the battery if you remove the white cover, but if you attemp to remove it you will damage the cables. You first need to unplug it by removing the end on the side of the LED as explained on the next steps. Only the side closer to the LED is necessary though.
    Fernando Socas - Yanıt
  3. JBL Charge 2 Plus Passive Radiators Replacement: adım 3, 2 resimden 1. JBL Charge 2 Plus Passive Radiators Replacement: adım 3, 2 resimden 2.
    • Remove the four screws that hold the passive radiator in place
    also there are no screws that hold the passive radiator in place.
    The screws are under the plastic cover you unscrewed before. You can pop it of with a flat screwdriver or your nails
  4. JBL Charge 2 Plus Passive Radiators Replacement: adım 4, 1 resimden 1.
    • Pop the Passive Radiator off.
  5. JBL Charge 2 Plus Passive Radiators Replacement: adım 5, 3 resimden 1. JBL Charge 2 Plus Passive Radiators Replacement: adım 5, 3 resimden 2. JBL Charge 2 Plus Passive Radiators Replacement: adım 5, 3 resimden 3.
    • Repeat Step 2, 3 and 4 for the other passive radiator.
    No, you only have to disconnect the right passive radiator to get to the battery and plug it.
    Gabriel Dug - Yanıt
    True. This step is unnecessary. You only need to pop the radiator under which the cables of the battery go.
    lukasz.kulbacki - Yanıt
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
John Reynolds
3.246 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Fall 2015 UMass Dartmouth, Team 4-1, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G1
4 Üyeler
12 adet Kılavuz yazıldı
3Kılavuz Yorumları
When charging my charge 2+ 4 LED lights are blowing but 5th one is not blowing , 5th one blows when Bluetooth is on that is when speaker is on . I don't know what to do please help mail at jomonjohny140898@gmail.com
Jomon johny - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 49
Her zaman: 17,898
