Ana içeriğe geç
JBL Charge 4 Speaker Replacement
Neye ihtiyacın var
  1. JBL Charge 4 Speaker Replacement, Speaker Grill: adım 1, 1 resimden 1.
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Speaker Replacement: adım 2, 2 resimden 1. JBL Charge 4 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Speaker Replacement: adım 3, 1 resimden 1.
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Speaker Replacement, Passive Bass Radiators: adım 4, 2 resimden 1. JBL Charge 4 Speaker Replacement, Passive Bass Radiators: adım 4, 2 resimden 2.
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Speaker Replacement: adım 5, 2 resimden 1. JBL Charge 4 Speaker Replacement: adım 5, 2 resimden 2.
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Speaker Replacement, Speaker: adım 6, 2 resimden 1. JBL Charge 4 Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Flip the device so that the speaker faces you.
    • Remove the four 8mm Phillips #1 screws.
  7. JBL Charge 4 Speaker Replacement: adım 7, 1 resimden 1.
    • Gently pull out the speaker.
  8. JBL Charge 4 Speaker Replacement: adım 8, 2 resimden 1. JBL Charge 4 Speaker Replacement: adım 8, 2 resimden 2.
    • Desolder the red and black wires.
    • A guide for soldering and desoldering can be found here.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Rohith Dara
357 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 üyesi
CPSU-WHITE-W19S1G1
4 Üyeler
26 adet Kılavuz yazıldı
11 Yorum
Perfect - But where to get the replacement speaker ??? I’ve searched whole web. Please give me the info about replacement speaker diaphragm. Regards, T
Tadej Tomašič - Yanıt
Jbl charge 4 Led indicator board G ribbon cable authentic
carlos maltez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 50
Son 30 gün: 201
Her zaman: 23,059
