Giriş
This guide will focus on removing the microphone.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$3.99
Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
There are three solder points that need to be desoldered.
If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
Use a desolder tool to remove the solder to the microphone.
If you are unsure how to desolder these connections, refer to How To Solder and Desolder Connections
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Love the sound of this speaker but I would like to disable the bluetooth signals. I only need and use the cable connection. I have contacted the manufacturer about this and they said the bluetooth cannot be disabled at the present set-up. Would you please show me how to disable or remove the bluetooth?
