Ana içeriğe geç
JBL Clip Plus Speaker Replacement
Neye ihtiyacın var
  1. JBL Clip Plus Speaker Replacement, Battery: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    $3.99
    Satın Al
    • Use the angled tweezers to carefully pull the rubber bumper off the back side of the device
  2. JBL Clip Plus Speaker Replacement: adım 2, 1 resimden 1.
    • There will be three 6mm philips head screws under that rubber bumper, remove these three screws.
  3. JBL Clip Plus Speaker Replacement: adım 3, 1 resimden 1.
    • The back cover should lift open easily and the components should be visible.
  4. JBL Clip Plus Speaker Replacement: adım 4, 1 resimden 1.
    • The battery is adhered to the back cover of the JBL Clip Plus, slowly lift the battery away from the case, using a spudger to pry the battery away from the adhesive.
  5. JBL Clip Plus Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the three 7mm philips head screws on the outer edges of the device.
  6. JBL Clip Plus Speaker Replacement: adım 6, 1 resimden 1.
    • Use the plastic prying tool to gently remove the face of the speaker from the body.
  7. JBL Clip Plus Speaker Replacement: adım 7, 1 resimden 1.
    • Use the spudger tool to gently scrape away the adhesive holding in the microphone.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  8. JBL Clip Plus Speaker Replacement: adım 8, 1 resimden 1.
    • Gently push the motherboard away from the microphone, this will allow you to remove the microphone.
  9. JBL Clip Plus Speaker Replacement: adım 9, 1 resimden 1.
    • Gently push the motherboard out from the frame of the JBL Clip Plus, this requires some force.
  10. JBL Clip Plus Speaker Replacement: adım 10, 1 resimden 1.
    • There are three solder points that need to be desoldered.
    • If you need help with desoldering refer to How to Solder and Desolder Connections help. After these are removed the battery should be free.
  11. JBL Clip Plus Speaker Replacement, Speaker: adım 11, 1 resimden 1.
    • There are two #1 philips head 4mm screw fastening the speaker to the body, remove these.
  12. JBL Clip Plus Speaker Replacement: adım 12, 1 resimden 1.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Noah Pauk
809 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-4, Baechle Spring 2016 IUPUI, Team 3-4, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S3G4
4 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
do you know were can i buy the new speaker for my jbl clip +?
ruitherock - Yanıt
I work in A/V. I frequently need to adjust audio systems.
I want to add a switch to the speaker wire, so I can turn the speaker off, and use the line out port only, in order to test audio systems with a Bluetooth reciver.
I can be at the mixing board, adjusting sliders while the music is playing, with no cables.
Will this work?
Donald Fournier - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 6,879
