Ana içeriğe geç
JBL Flip Speaker Replacement
Neye ihtiyacın var
  1. JBL Flip Speaker Replacement, JBL Flip disassembly: adım 1, 3 resimden 1. JBL Flip Speaker Replacement, JBL Flip disassembly: adım 1, 3 resimden 2. JBL Flip Speaker Replacement, JBL Flip disassembly: adım 1, 3 resimden 3.
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Flip Speaker Replacement: adım 2, 3 resimden 1. JBL Flip Speaker Replacement: adım 2, 3 resimden 2. JBL Flip Speaker Replacement: adım 2, 3 resimden 3.
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
    FixBot'a Sor
    Yorum Ekle
  3. JBL Flip Speaker Replacement: adım 3, 3 resimden 1. JBL Flip Speaker Replacement: adım 3, 3 resimden 2. JBL Flip Speaker Replacement: adım 3, 3 resimden 3.
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Flip Speaker Replacement: adım 4, 1 resimden 1.
    • Remove last white back plate to expose the back of the speaker cover.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Flip Speaker Replacement: adım 5, 3 resimden 1. JBL Flip Speaker Replacement: adım 5, 3 resimden 2. JBL Flip Speaker Replacement: adım 5, 3 resimden 3.
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Flip Speaker Replacement: adım 6, 3 resimden 1. JBL Flip Speaker Replacement: adım 6, 3 resimden 2. JBL Flip Speaker Replacement: adım 6, 3 resimden 3.
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
    FixBot'a Sor
    Yorum Ekle
  7. JBL Flip Speaker Replacement, Speaker: adım 7, 3 resimden 1. JBL Flip Speaker Replacement, Speaker: adım 7, 3 resimden 2. JBL Flip Speaker Replacement, Speaker: adım 7, 3 resimden 3.
    • Remove screws that hold the plastic L-pipe in place.
    FixBot'a Sor
    Yorum Ekle
  8. JBL Flip Speaker Replacement: adım 8, 2 resimden 1. JBL Flip Speaker Replacement: adım 8, 2 resimden 2.
    • Remove L-pipe.
    • Remove two screws on each speaker.
    • Remove speakers.
    FixBot'a Sor
    Yorum Ekle
  9. JBL Flip Speaker Replacement: adım 9, 3 resimden 1. JBL Flip Speaker Replacement: adım 9, 3 resimden 2. JBL Flip Speaker Replacement: adım 9, 3 resimden 3.
    • Take a soldering iron to the two solders, one for each cable.
    • Soldering iron will be very hot.
    • Once the soldering has melted, remove each wire from the speaker.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Dillon
1.622 İtibar
5 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 9-5, Panko Spring 2015 Colorado Springs, Team 9-5, Panko Spring 2015 üyesi
UCCS-PANKO-S15S9G5
3 Üyeler
9Kılavuz Yorumları
I want JBL flip 2 charging commector board.
Where can i buy ??
Plz help me
feroz4u786 - Yanıt Paylaş
Where do you buy the replacement speakers?
ingridxpan - Yanıt Paylaş
I have a problem with the bluetooth of my speaker goes off after 10 minutes of running I have checked with several smart and it always repeats that I can do
Alvaro Rivas Rodriguez - Yanıt Paylaş
Where I can get schematic diagram and plans of this equipment
I want to buy 2pcs replacement speaker for my JBL flip bluetooth speaker. Ho can I buy .and from
jonessangeeta - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 69
Her zaman: 43,630
