Ana içeriğe geç
JBL Go 3 Driver Replacement
Neye ihtiyacın var
  1. JBL Go 3 Driver Replacement, Driver: adım 1, 2 resimden 1. JBL Go 3 Driver Replacement, Driver: adım 1, 2 resimden 2.
    • Hold the power button until the JBL Go 3 shuts off
    • Disconnect any charging cables
    • Use jimmy to remove the hard shell
    • Work your way around the edges slowly—be patient as it's glued or snapped in tightly
  2. JBL Go 3 Driver Replacement: adım 2, 3 resimden 1. JBL Go 3 Driver Replacement: adım 2, 3 resimden 2. JBL Go 3 Driver Replacement: adım 2, 3 resimden 3.
    • Once the hard shell is removed,use jimmy to lift up the speaker part.
    • Locate the internal screws underneath the outer shell.
    • Use your precision screwdriver to remove all screws securing the plastic enclosure.
    • Carefully lift the casing to expose the speaker and other internal components.
  3. JBL Go 3 Driver Replacement: adım 3, 2 resimden 1. JBL Go 3 Driver Replacement: adım 3, 2 resimden 2.
    • If accessible, unplug the battery to prevent any electrical short while working.
    • If it's soldered, proceed carefully and avoid touching metal contacts unnecessarily.
    • Unscrew any fasteners holding the speaker in place.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Kasey Oliver
507 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Konn Spring 2025 UMass Dartmouth, Team 4-5, Konn Spring 2025 üyesi
UMASSD-KONN-S25S4G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 326
