Giriş
If your JBL stops turning on or won’t charge when showing no signs of working with a working charger or battery, use this guide to replace the internal motherboard.
Neye ihtiyacın var
Using an iFixit Opening Pick or a Jimmy, pry along the seam between the rubber outer layer and the hard shell.
Work your way around the edges until the shell loosens and can be fully removed.
Locate the internal screws underneath the outer shell.
Use your precision screwdriver to remove all screws securing the plastic enclosure.
Carefully lift the casing to expose the motherboard and other internal components.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
