Ana içeriğe geç
JBL Go 4 Motherboard Replacement
Neye ihtiyacın var
  1. JBL Go 4 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. JBL Go 4 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Use an opening tool to pry off both sides of the speaker cover.
    • Make sure to be careful to not force it apart and break it.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Go 4 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the Phillips screws securing the motherboard.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Go 4 Motherboard Replacement: adım 3, 2 resimden 1. JBL Go 4 Motherboard Replacement: adım 3, 2 resimden 2.
    • Gently remove the white and red pieces from their connectors on the motherboard with your hands.
    • They should come out relatively easy, this is the last piece needed before removing the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Go 4 Motherboard Replacement: adım 4, 3 resimden 1. JBL Go 4 Motherboard Replacement: adım 4, 3 resimden 2. JBL Go 4 Motherboard Replacement: adım 4, 3 resimden 3.
    • Use an opening tool to pry the motherboard away from the rest of the speaker.
    • Make sure to be very gentle, to cause no damage to the rest of the speaker.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Chad Bernstein
159 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Konn Spring 2025 UMass Dartmouth, Team 4-1, Konn Spring 2025 üyesi
UMASSD-KONN-S25S4G1
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 20
Son 30 gün: 103
Her zaman: 880
