Ana içeriğe geç
JBL Go 4 Motherboard Replacement
Neye ihtiyacın var
  1. JBL Go 4 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. JBL Go 4 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Use an opening tool to pry off both sides of the speaker cover.
    • Make sure to be careful to not force it apart and break it.
  2. JBL Go 4 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the Phillips screws securing the motherboard.
  3. JBL Go 4 Motherboard Replacement: adım 3, 2 resimden 1. JBL Go 4 Motherboard Replacement: adım 3, 2 resimden 2.
    • Gently remove the white and red pieces from their connectors on the motherboard with your hands.
    • They should come out relatively easy, this is the last piece needed before removing the motherboard.
  4. JBL Go 4 Motherboard Replacement: adım 4, 3 resimden 1. JBL Go 4 Motherboard Replacement: adım 4, 3 resimden 2. JBL Go 4 Motherboard Replacement: adım 4, 3 resimden 3.
    • Use an opening tool to pry the motherboard away from the rest of the speaker.
    • Make sure to be very gentle, to cause no damage to the rest of the speaker.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Chad Bernstein
159 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Konn Spring 2025 UMass Dartmouth, Team 4-1, Konn Spring 2025 üyesi
UMASSD-KONN-S25S4G1
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 257
