Ana içeriğe geç
JBL Go 4 Outer Shell Replacement
Neye ihtiyacın var
    1. JBL Go 4 Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 1. JBL Go 4 Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 2. JBL Go 4 Outer Shell Replacement, Outer Shell: adım 1, 3 resimden 3.
      • Remove the speaker's grille by inserting the tip of an opening tool into the top corner, opposite the strap.
      • Slide the tool along the edge of the housing until it pops off. Place it to the side.
      • Be sure that the battery has been drained completely before attempting this replacement.
      FixBot'a Sor
      Yorum Ekle
    2. JBL Go 4 Outer Shell Replacement: adım 2, 3 resimden 1. JBL Go 4 Outer Shell Replacement: adım 2, 3 resimden 2. JBL Go 4 Outer Shell Replacement: adım 2, 3 resimden 3.
      • Insert the same opening tool in the opposite corner, lifting carefully.
      • Slide the tool along the edge until the cover pops off.
      • Gently pull the housing up and to the side.
      • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
      FixBot'a Sor
      Yorum Ekle
    3. JBL Go 4 Outer Shell Replacement: adım 3, 1 resimden 1.
      • At this point, you should switch over to the JBL Go 4 Battery Replacement, and follow the steps to remove the battery
      • Once the battery is removed, use a strong adhesive to adhere it to the new shell and follow the steps in reverse.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jackosn Caron
255 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Konn Spring 2025 UMass Dartmouth, Team 4-1, Konn Spring 2025 üyesi
UMASSD-KONN-S25S4G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 23
Son 30 gün: 107
Her zaman: 876
