Giriş
In this Replacement Guide, you will find the steps and process to replace the battery in the JBL Go 4.
The Battery provides power to the entire device. A failing battery can have reduced battery life or none at all, it can also begin to overheat or shut down at random times.
Before using this guide, make sure to review the troubleshooting page—oftentimes, there can be other reasons for shortened battery life.
Note: The device used in this guide is a non-genuine model, so the internal components may look different from those in your authentic device. However, the replacement procedure remains roughly the same and should still apply to your device.
Neye ihtiyacın var
Insert an opening tool into the seam in between the grille and chassis, in the top corner opposite the strap.
Slide the tool along the edge of the housing until the grille releases.
Remove the grille.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2Kılavuz Yorumları
Great guide, thanks! Small point -
Typo - “Insert an opening into the seam”. I think you’re missing ‘tool’.
Thanks for pointing that out, @alexanderdyas. We took care of the typo. In the future, feel free to go ahead and make the edit!
