Giriş
Having trouble charging your JBL Xtreme 4? This guide will walk you through the steps to replace the charging port.
One of the most common signs of a faulty charging port is when your device won't charge even when connected to a working power source. Before jumping into the replacement process, we recommend reviewing our Troubleshooting Guide to confirm that the charging port is the root of the issue.
Before beginning the replacement, ensure your device is powered off and disconnected from any external power source.
Neye ihtiyacın var
Use a T20 Torx screwdriver to remove the two 12.5 mm screws that secure the battery cover.
Insert the flat end of a spudger into the mesh cover seam beside the battery compartment.
Pry on both sides of the battery compartment until the mesh cover releases.
Remove the two 8.5 mm Phillips screws on the charging port cover.
Pry the cover off with an opening tool.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
