Ana içeriğe geç
JBL Xtreme Charging Port Replacement
Neye ihtiyacın var
  1. JBL Xtreme Charging Port Replacement, Cover: adım 1, 1 resimden 1.
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Charging Port Replacement: adım 2, 2 resimden 1. JBL Xtreme Charging Port Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Charging Port Replacement: adım 3, 2 resimden 1. JBL Xtreme Charging Port Replacement: adım 3, 2 resimden 2.
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Charging Port Replacement, Bass Radiator: adım 4, 3 resimden 1. JBL Xtreme Charging Port Replacement, Bass Radiator: adım 4, 3 resimden 2. JBL Xtreme Charging Port Replacement, Bass Radiator: adım 4, 3 resimden 3.
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Charging Port Replacement: adım 5, 3 resimden 1. JBL Xtreme Charging Port Replacement: adım 5, 3 resimden 2. JBL Xtreme Charging Port Replacement: adım 5, 3 resimden 3.
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
  6. JBL Xtreme Charging Port Replacement, Charging Port: adım 6, 3 resimden 1. JBL Xtreme Charging Port Replacement, Charging Port: adım 6, 3 resimden 2. JBL Xtreme Charging Port Replacement, Charging Port: adım 6, 3 resimden 3.
    • Locate and disconnect the the three plugs indicated in these pictures.
  7. JBL Xtreme Charging Port Replacement: adım 7, 2 resimden 1. JBL Xtreme Charging Port Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Unplug the three ports from the previous step.
    • A set of tweezers may be helpful to reach deeper into the device.
  8. JBL Xtreme Charging Port Replacement: adım 8, 3 resimden 1. JBL Xtreme Charging Port Replacement: adım 8, 3 resimden 2. JBL Xtreme Charging Port Replacement: adım 8, 3 resimden 3.
    • Locate the three Phillips head screws inside the zipper compartment and unscrew them.
    • Pull the zipper panel free from the device.
  9. JBL Xtreme Charging Port Replacement: adım 9, 3 resimden 1. JBL Xtreme Charging Port Replacement: adım 9, 3 resimden 2. JBL Xtreme Charging Port Replacement: adım 9, 3 resimden 3.
    • Under the zipper panel are eight more Phillips head screws. Unscrew them and carefully lift the battery cover.
    • Be careful not to damage the small white ribbon cable which connects the battery cover to the rest of the device.
  10. JBL Xtreme Charging Port Replacement: adım 10, 2 resimden 1. JBL Xtreme Charging Port Replacement: adım 10, 2 resimden 2.
    • Unscrew the three 11.88mm Phillips head screws highlighted in the picture.
  11. JBL Xtreme Charging Port Replacement: adım 11, 2 resimden 1. JBL Xtreme Charging Port Replacement: adım 11, 2 resimden 2.
    • Pull the Auxiliary board out.
    • There is foam covering the wires, making it difficult to remove the Auxiliary board. Take your time with this step.
  12. JBL Xtreme Charging Port Replacement: adım 12, 3 resimden 1. JBL Xtreme Charging Port Replacement: adım 12, 3 resimden 2. JBL Xtreme Charging Port Replacement: adım 12, 3 resimden 3.
    • The first image highlights the charging port.
    • Locate 6 metal pins highlighted in the second image and use a solder iron to disconnect the pins.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Benny Huynh
1.953 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Sullivan Spring 2017 USF Tampa, Team 1-1, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G1
4 Üyeler
27 adet Kılavuz yazıldı
Bir Yorum
Please I have a JBL XTREME that sparks each time I plug it. What could be the cause
morris_ugwoke - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 50
Son 30 gün: 214
Her zaman: 22,118
