Ana içeriğe geç
Jabra Speak 510 Battery Replacement
Neye ihtiyacın var
  1. Jabra Speak 510 Battery Replacement, Outer Casing: adım 1, 2 resimden 1. Jabra Speak 510 Battery Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Battery Replacement: adım 3, 2 resimden 1. Jabra Speak 510 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Battery Replacement: adım 4, 3 resimden 1. Jabra Speak 510 Battery Replacement: adım 4, 3 resimden 2. Jabra Speak 510 Battery Replacement: adım 4, 3 resimden 3.
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Battery Replacement, Battery: adım 5, 2 resimden 1. Jabra Speak 510 Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Once you have carefully separated the bottom case from the top case, locate the two batteries attached to the motherboard.
    • Notice that each battery has two wires, one red and the other black, soldered to the board. Make a careful note of which is soldered to which pad.
    • Desolder the battery connections using the heated soldering iron.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
  6. Jabra Speak 510 Battery Replacement: adım 6, 1 resimden 1.
    • The battery is glued to the motherboard. Take care not to damage it in any way with excessive force in removing it.
    • Carefully pry the battery away from the motherboard using a plastic opening tool. The glue gives very slowly under constant pressure and cannot be hurried. As the battery starts to lift you can insert the prying tool further as you continue to lift the battery.
    • The adhesive may still have sufficient stickiness to hold the new batteries, but if not, replace it with double sided tape.
    • Solder the wires of the new batteries to the board, making sure that the red and black go to the correct pads.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Edgar Tavares
468 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Harley Spring 2016 IUPUI, Team 2-3, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S2G3
4 Üyeler
8 adet Kılavuz yazıldı
9 Yorum
Thanks pal!
Freezing the headset in an airtight bag for 24 hours worked.
Best wishes,
Ronny
Norway
Ronny - Yanıt
Very precisely described steps, super well written - excellent job Ed, thanks
Rafael Benitez - Yanıt
Thank`s so much! Great job!
Artur Michalski - Yanıt
Very helpful. If I want to bypass the battery, how can I do? Thanks a lot.
Bruce.Hsu - Yanıt
Is it possible to change the USB cable?
publicidad publicidad - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 79
Son 30 gün: 355
Her zaman: 31,602
