Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
Remove the six 20 mm T6 screws from the bottom of the device.
Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
Slowly flip the device open like a clam shell.
Once you have carefully separated the bottom case from the top case, locate the two batteries attached to the motherboard.
Desolder the battery connections using the heated soldering iron.
Carefully pry the battery away from the motherboard using a plastic opening tool. The glue gives very slowly under constant pressure and cannot be hurried. As the battery starts to lift you can insert the prying tool further as you continue to lift the battery.
The adhesive may still have sufficient stickiness to hold the new batteries, but if not, replace it with double sided tape.
Solder the wires of the new batteries to the board, making sure that the red and black go to the correct pads.
20 farklı kişi bu kılavuzu tamamladı.
9 Yorum
Very precisely described steps, super well written - excellent job Ed, thanks
Thank`s so much! Great job!
Is it possible to change the USB cable?
