Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
Remove the six 20 mm T6 screws from the bottom of the device.
Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
Slowly flip the device open like a clam shell.
Using the T6 Torx Screwdriver, remove the four (4mm) screws.
After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
Peel off the white adhesive to desolder the connections underneath.
Desolder the wires connected to the motherboard.
4 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Great walk-through... thanks
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
