Ana içeriğe geç
Jabra Speak 510 Speaker Replacement
Neye ihtiyacın var
  1. Jabra Speak 510 Speaker Replacement, Outer Casing: adım 1, 2 resimden 1. Jabra Speak 510 Speaker Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Speaker Replacement: adım 3, 2 resimden 1. Jabra Speak 510 Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Speaker Replacement: adım 4, 3 resimden 1. Jabra Speak 510 Speaker Replacement: adım 4, 3 resimden 2. Jabra Speak 510 Speaker Replacement: adım 4, 3 resimden 3.
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Speaker Replacement, Speaker: adım 5, 2 resimden 1. Jabra Speak 510 Speaker Replacement, Speaker: adım 5, 2 resimden 2.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jordan Murphy
717 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Harley Spring 2016 IUPUI, Team 2-3, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S2G3
4 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
soleniall buen aporteee
bryanpinedaza - Yanıt
Excelente aporte! Me sirvió mucho!
Alex - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 34
Her zaman: 5,422
