Ana içeriğe geç
Jabra Speak 510 Speaker Replacement
Neye ihtiyacın var
  1. Jabra Speak 510 Speaker Replacement, Outer Casing: adım 1, 2 resimden 1. Jabra Speak 510 Speaker Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the six 20 mm T6 screws from the bottom of the device.
    Remove the screws using T6 Torx screwdriver.
    Taha Asad - Yanıt
  3. Jabra Speak 510 Speaker Replacement: adım 3, 2 resimden 1. Jabra Speak 510 Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Speaker Replacement: adım 4, 3 resimden 1. Jabra Speak 510 Speaker Replacement: adım 4, 3 resimden 2. Jabra Speak 510 Speaker Replacement: adım 4, 3 resimden 3.
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
    The hooks on the plastic tabs point inwards. You can see the counterpart of a hook on the 2nd picture on the left of the battery.
    I released the hooks by pushing the plastic pads outwards, gently pulling a flat-head screwdriver towards the center. It is necessary to pull the screwdriver ca. 3mm back from the maximum possible depth (otherwise you would push the counterpart outwards, instead of the plastic pad).
    Franz - Yanıt
  5. Jabra Speak 510 Speaker Replacement, Speaker: adım 5, 2 resimden 1. Jabra Speak 510 Speaker Replacement, Speaker: adım 5, 2 resimden 2.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jordan Murphy
717 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-3, Harley Spring 2016 IUPUI, Team 2-3, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S2G3
4 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
soleniall buen aporteee
bryanpinedaza - Yanıt
Excelente aporte! Me sirvió mucho!
Alex - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 60
Her zaman: 5,294
