Ana içeriğe geç
Jam XT HX-P430 Disassembly
Neye ihtiyacın var
  1. Jam XT HX-P430 Disassembly, Casing: adım 1, 1 resimden 1.
    • You can really take this off however you want but here's a pic.
  2. Jam XT HX-P430 Disassembly, Speaker Guard: adım 2, 3 resimden 1. Jam XT HX-P430 Disassembly, Speaker Guard: adım 2, 3 resimden 2. Jam XT HX-P430 Disassembly, Speaker Guard: adım 2, 3 resimden 3.
    • Using a spudger or similar pry the guard off one side at a time.
  3. Jam XT HX-P430 Disassembly, Screws!: adım 3, 2 resimden 1. Jam XT HX-P430 Disassembly, Screws!: adım 3, 2 resimden 2.
    • Remove the screws for the speaker and the four that are down the holes.
    • It isn't necessary but I removed the d-ring as well.
  4. Jam XT HX-P430 Disassembly, Case: adım 4, 3 resimden 1. Jam XT HX-P430 Disassembly, Case: adım 4, 3 resimden 2. Jam XT HX-P430 Disassembly, Case: adım 4, 3 resimden 3.
    • Remove the black button spacers. (Note: There are 3 spacers I lost one).
    • Push the white bottom through the hole and slowly wiggle the blue case off. Be careful not to break the speaker cables.
    • Now remove the four screws.
  5. Jam XT HX-P430 Disassembly, Board and Battery.: adım 5, 3 resimden 1. Jam XT HX-P430 Disassembly, Board and Battery.: adım 5, 3 resimden 2. Jam XT HX-P430 Disassembly, Board and Battery.: adım 5, 3 resimden 3.
    • They used black silicone to keep the connectors together so the entire assembly may come off. I suggest making sure you know how the go back together.
    • Carefully using a knife try to split the silicone so the connectors come off easily.
    • Next remove the fours screws holding the board in. (Note: There is two matching pairs.)
    • Using the spudger remove the battery from the white plastic.
  6. Jam XT HX-P430 Disassembly, Finished!: adım 6, 2 resimden 1. Jam XT HX-P430 Disassembly, Finished!: adım 6, 2 resimden 2.
    • Yay! It is disassembled.
    • (Note: There are 3 spacers I lost one).
Sonuç
Wolf Andrew
133 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Is the amp bridgable ?
jonathan s - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 807
