Ana içeriğe geç
Jazz UltraTab C855 Motherboard Replacement
Neye ihtiyacın var
    1. Jazz UltraTab C855 Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    2. Jazz UltraTab C855 Motherboard Replacement: adım 2, 1 resimden 1.
      • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
      FixBot'a Sor
      Yorum Ekle
    1. Jazz UltraTab C855 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
      • Remove the two pieces of tape securing the ribbon cables to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Jazz UltraTab C855 Motherboard Replacement: adım 4, 1 resimden 1.
      • Remove the 3 screws at the top of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Jazz UltraTab C855 Motherboard Replacement: adım 5, 1 resimden 1.
      • Using a plastic prying tool, lift open the latch that secures the ribbon cable next to the speaker.
      • Pull the ribbon cable out of its connector on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Jazz UltraTab C855 Motherboard Replacement: adım 6, 1 resimden 1.
      • Use a plastic prying tool to disconnect the other ribbon cable from the motherboard. This cable belongs to the device's cameras.
      FixBot'a Sor
      Yorum Ekle
    5. Jazz UltraTab C855 Motherboard Replacement: adım 7, 1 resimden 1.
      • Disconnect the large ribbon cable from the motherboard. Do this by unlocking the tabs on each side of the connector.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      FixBot'a Sor
      Yorum Ekle
    6. Jazz UltraTab C855 Motherboard Replacement: adım 8, 1 resimden 1.
      • Snip the two sets of wires that are attached to the motherboard. Cut the wires as close to the board as possible. This will leave plenty of length to reattach the wires to the new board.
      • Skip this step if you are only removing the motherboard to replace the screen.
      • During reassembly, we recommend soldering or crimping the wires away from the motherboard contacts. You should avoid soldering directly to the motherboard unless absolutely necessary. To learn more about soldering, check out iFixit's Soldering Skills Guide
      FixBot'a Sor
      Yorum Ekle
Sonuç
andres maynez
113 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Baechle Fall 2015 IUPUI, Team 1-3, Baechle Fall 2015 üyesi
IUPUI-BAECHLE-F15S1G3
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 733
