Ana içeriğe geç
Jumper Angelsounds JPD-100S Headphone Jacks Replacement
Neye ihtiyacın var
  1. Jumper Angelsounds JPD-100S Headphone Jacks Replacement, Motherboard: adım 1, 1 resimden 1.
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 2, 2 resimden 1. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 2, 2 resimden 2.
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 3, 1 resimden 1.
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 4, 2 resimden 1. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 4, 2 resimden 2.
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 5, 2 resimden 1. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 5, 2 resimden 2.
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 6, 1 resimden 1.
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 7, 1 resimden 1.
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Headphone Jacks Replacement, Headphone Jacks: adım 8, 1 resimden 1.
    • Take the battery connector out of the battery compartment.
  9. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 9, 1 resimden 1.
    • Preheat the soldering iron .
    • Locate the wires that connect to the transducer.
    • Use a soldering iron and solder vacuum to unsolder the wires connected to the transducer.
  10. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 10, 2 resimden 1. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 10, 2 resimden 2.
    • Place the motherboard in a position that allows easy access to the jacks.
  11. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 11, 3 resimden 1. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 11, 3 resimden 2. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 11, 3 resimden 3.
    • Desolder the three solder joints securing each of the headphone jacks.
    • Try not to melt the motherboard when removing solder that secures the jacks.
  12. Jumper Angelsounds JPD-100S Headphone Jacks Replacement: adım 12, 1 resimden 1.
    • Remove the jacks by pulling them out of the motherboard.
Sonuç
Yessika Lugo
113 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 6-1, Remmell Fall 2015 USF Tampa, Team 6-1, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S6G1
6 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 366
