Ana içeriğe geç
KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement
Neye ihtiyacın var
  1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: adım 1, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: adım 1, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement, Matias Quiet Click Alps Key Switch: adım 1, 3 resimden 3.
    • Insert the key cap puller into the cracks around the keycap.
    • Twist the tool around the bottom of the keycap.
    • Hold the keyboard down, and pull on the keycap slowly.
    • Pull up as straight as possible.
    • Force required to pull a keycap may vary from soft to heavy.
  2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 2, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 2, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 2, 3 resimden 3.
    • Proceed to remove the surrounding keycaps.
  3. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 3, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 3, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 3, 3 resimden 3.
    • Flip the keyboard over so that the bottom is facing upward.
    • Slip an opening pick beneath the warranty sticker.
    • Proceed to pull the sticker off to reveal the hole.
  4. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 4, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 4, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #1 Screwdriver to remove the 10 mm screw.
  5. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 5, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 5, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 5, 3 resimden 3.
    • Slip an opening tool into the cracks at the indicated points.
    • Pry open carefully.
  6. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 6, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 6, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 6, 3 resimden 3.
    • Flip the keyboard so that the keys are facing upward.
    • Grab the sides of the top case and pull up gently.
  7. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 7, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 7, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 7, 3 resimden 3.
    • Separate the plate from the bottom case slightly.
    • Reach within and remove the daughterboard cable.
  8. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 8, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 8, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 8, 3 resimden 3.
    • Turn the plate over.
    • Locate the pins for the key switch.
    • All the key switches are labeled with their ASCII designation.
  9. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 9, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 9, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    • Desolder the pins with a soldering iron and a desoldering pump.
    • Repeat until the pins freely move inside the wells without heat.
    • Placing the soldering iron too close to the PCB may damage it.
  10. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 10, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 10, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 10, 3 resimden 3.
    • Wedge two opening tools under the key switch.
    • Pull up gently.
    • If the key switch appears to be immovable, consider repeating step 9.
  11. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 11, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 11, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 11, 3 resimden 3.
    • Insert a new key switch into the well with pins corresponding to that of the PCBs.
  12. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 12, 3 resimden 1. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 12, 3 resimden 2. KBParadise V80 TKL Mechanical Keyboard Alps Key Switch Replacement: adım 12, 3 resimden 3.
    • Solder the pins onto the PCB ensuring the solder stays within the wells of the pins.
    • Ensure the pins do not freely move after soldering.
    • Ensure that there is no solder connecting the two pins, as this can possibly cause a short circuit.
Sonuç
To reassemble your device, follow these instructions in reverse order starting at step 7.
2 farklı kişi bu kılavuzu tamamladı.
Kenny Nguyen
268 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 1,982
