Giriş
Use this guide to replace the Limit Switch that tells the Keurig that the K-Cup section is closed.
Neye ihtiyacın var
Remove the switch by cuting the two connecting wires. Reconnect a replacement switch using this guide to join wires with solder, or using this guide to solder connections, or by using any other technique to connect wires.
Bir başkası bu kılavuzu tamamladı.
