Ana içeriğe geç
Keychron K10 Max Wireless Keycap Replacement
Neye ihtiyacın var
    1. Keychron K10 Max Wireless Keycap Replacement, Keycap: adım 1, 3 resimden 1. Keychron K10 Max Wireless Keycap Replacement, Keycap: adım 1, 3 resimden 2. Keychron K10 Max Wireless Keycap Replacement, Keycap: adım 1, 3 resimden 3.
      • Lay the keyboard face down on the workspace.
      • Use a 2.5 mm hex screwdriver to remove the eight 4.5 mm screws from the back case.
      • Carefully separate the front frame from the keyboard and set it aside.
      • There is a clear shield that sits right above the arrow keys. This shield is to diffuse the LEDs from the keyboard, and it can fall out easily. Just remember to put it back if it does when reassembly.
      FixBot'a Sor
      Yorum Ekle
    2. Keychron K10 Max Wireless Keycap Replacement: adım 2, 2 resimden 1. Keychron K10 Max Wireless Keycap Replacement: adım 2, 2 resimden 2.
      • Slide the keycap puller over the keycap until it grips underneath.
      • Pull straight upward to remove the keycap.
      • Sometimes the mechanical switch itself comes with the keycap. Just remove the switch from the button and reinstall the switch.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 115
