Ana içeriğe geç
Kidzlane Walkie-Talkie Antenna Replacement
Neye ihtiyacın var
  1. Kidzlane Walkie-Talkie Antenna Replacement, Antenna: adım 1, 1 resimden 1.
    • Flip your device over so the back panel is facing up.
  2. Kidzlane Walkie-Talkie Antenna Replacement: adım 2, 2 resimden 1. Kidzlane Walkie-Talkie Antenna Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #00 Screwdriver to unscrew the four 4mm screws shown.
    • Take out the three batteries from the device.
  3. Kidzlane Walkie-Talkie Antenna Replacement: adım 3, 2 resimden 1. Kidzlane Walkie-Talkie Antenna Replacement: adım 3, 2 resimden 2.
    • Gently separate the front and back panels of the device.
    • Gently remove the green circuit board and the black speaker from the plastic casing.
  4. Kidzlane Walkie-Talkie Antenna Replacement: adım 4, 1 resimden 1.
    • Flip the green circuit board over, so that the end of the antenna is visible. Use the soldering iron to disconnect the antenna.
    • Carefully remove the antenna from the circuit board.
    • The antenna may be hot from the soldering device.
Sonuç
To reassemble your Kidzlane Walkie-Talkie, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Amin
642 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Wilson Spring 2016 IUPUI, Team 1-1, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S1G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,010
