Ana içeriğe geç
Kindle Fire HD 8.9" Camera Replacement
Neye ihtiyacın var
  1. Kindle Fire HD 8.9" Camera Replacement, Screen: adım 1, 3 resimden 1. Kindle Fire HD 8.9" Camera Replacement, Screen: adım 1, 3 resimden 2. Kindle Fire HD 8.9" Camera Replacement, Screen: adım 1, 3 resimden 3.
    • Insert a large plastic opening tool next to the Kindle's headphone jack.
    • Make sure the notch on the plastic opening tool is facing the back of the Kindle.
    • Move the plastic opening tool evenly around the Kindle, separating the two halves.
    • Be careful not to completely separate the rear cover. There are two delicate flex cables that connect the display assembly to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  2. Kindle Fire HD 8.9" Camera Replacement: adım 2, 1 resimden 1.
    • Set the Kindle down on the rear case.
    • Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
    • These images show the Kindle laying flat. In order to prevent damage to the flex cables, keep the Kindle open at 90 degrees while disconnecting the display assembly.
    FixBot'a Sor
    Yorum Ekle
  3. Kindle Fire HD 8.9" Camera Replacement: adım 3, 3 resimden 1. Kindle Fire HD 8.9" Camera Replacement: adım 3, 3 resimden 2. Kindle Fire HD 8.9" Camera Replacement: adım 3, 3 resimden 3.
    • Lift the retaining flap on the ZIF connector of the upper flex cable.
    • Gently pull the cable out of its socket.
    • This flex cable is delicate. Be careful not to crease or bend it while working.
    FixBot'a Sor
    Yorum Ekle
  4. Kindle Fire HD 8.9" Camera Replacement: adım 4, 1 resimden 1.
    • Separate the display assembly from the rest of the device.
    • When reassembling the device, align the two halves of the case before connecting the flex cables.
    FixBot'a Sor
    Yorum Ekle
  5. Kindle Fire HD 8.9" Camera Replacement, Inner Metal Casing: adım 5, 2 resimden 1. Kindle Fire HD 8.9" Camera Replacement, Inner Metal Casing: adım 5, 2 resimden 2.
    • Remove the following sixteen screws from the metal midframe on the rear of the device:
    • Four 3 mm Phillips screw (located in each corner of the device - noted in red in the diagram)
    • Four 3 mm Phillips screws (surrounding the ports - noted in orange in the diagram)
    • Eight 3 mm Phillips screws (located around the body of the midframe - noted in yellow in the diagram)
    FixBot'a Sor
    Yorum Ekle
  6. Kindle Fire HD 8.9" Camera Replacement: adım 6, 2 resimden 1. Kindle Fire HD 8.9" Camera Replacement: adım 6, 2 resimden 2.
    • Carefully remove the metal midframe.
    FixBot'a Sor
    Yorum Ekle
  7. Kindle Fire HD 8.9" Camera Replacement, Camera: adım 7, 3 resimden 1. Kindle Fire HD 8.9" Camera Replacement, Camera: adım 7, 3 resimden 2. Kindle Fire HD 8.9" Camera Replacement, Camera: adım 7, 3 resimden 3.
    • After taking off the metal casing, locate the camera.
    • Use your index finger to carefully lift up the silver clip located just under the camera. It will click when it comes loose.
    • After you snap up the silver clip, move your finger to the opposite side so that you are now pointing into the Kindle.
    • Push the camera outwards towards the edge of the device in order to remove it.
    • Make sure to keep the parts in a safe area to avoid any damage to the camera and its lens.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ted Park
34 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-16, Forte Winter 2013 Cal Poly, Team 5-16, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G16
5 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 40
Her zaman: 2,104
