Ana içeriğe geç
Kindle Fire HD 8.9" Midframe Replacement
Neye ihtiyacın var
    1. Kindle Fire HD 8.9" Midframe Replacement, Screen: adım 1, 3 resimden 1. Kindle Fire HD 8.9" Midframe Replacement, Screen: adım 1, 3 resimden 2. Kindle Fire HD 8.9" Midframe Replacement, Screen: adım 1, 3 resimden 3.
      • Insert a large plastic opening tool next to the Kindle's headphone jack.
      • Make sure the notch on the plastic opening tool is facing the back of the Kindle.
      • Move the plastic opening tool evenly around the Kindle, separating the two halves.
      • Be careful not to completely separate the rear cover. There are two delicate flex cables that connect the display assembly to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Fire HD 8.9" Midframe Replacement: adım 2, 1 resimden 1.
      • Set the Kindle down on the rear case.
      • Holding the display assembly near the camera, carefully open the display assembly up to about 90 degrees from the rear case.
      • These images show the Kindle laying flat. In order to prevent damage to the flex cables, keep the Kindle open at 90 degrees while disconnecting the display assembly.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle Fire HD 8.9" Midframe Replacement: adım 3, 3 resimden 1. Kindle Fire HD 8.9" Midframe Replacement: adım 3, 3 resimden 2. Kindle Fire HD 8.9" Midframe Replacement: adım 3, 3 resimden 3.
      • Lift the retaining flap on the ZIF connector of the upper flex cable.
      • Gently pull the cable out of its socket.
      • This flex cable is delicate. Be careful not to crease or bend it while working.
      FixBot'a Sor
      Yorum Ekle
    4. Kindle Fire HD 8.9" Midframe Replacement: adım 4, 1 resimden 1.
      • Separate the display assembly from the rest of the device.
      • When reassembling the device, align the two halves of the case before connecting the flex cables.
      FixBot'a Sor
      Yorum Ekle
    1. Kindle Fire HD 8.9" Midframe Replacement, Inner Metal Casing: adım 5, 2 resimden 1. Kindle Fire HD 8.9" Midframe Replacement, Inner Metal Casing: adım 5, 2 resimden 2.
      • Remove the following sixteen screws from the metal midframe on the rear of the device:
      • Four 3 mm Phillips screw (located in each corner of the device - noted in red in the diagram)
      • Four 3 mm Phillips screws (surrounding the ports - noted in orange in the diagram)
      • Eight 3 mm Phillips screws (located around the body of the midframe - noted in yellow in the diagram)
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Fire HD 8.9" Midframe Replacement: adım 6, 2 resimden 1. Kindle Fire HD 8.9" Midframe Replacement: adım 6, 2 resimden 2.
      • Carefully remove the metal midframe.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ted Park
34 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-16, Forte Winter 2013 Cal Poly, Team 5-16, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G16
5 Üyeler
63 adet Kılavuz yazıldı
2Kılavuz Yorumları
I suggest not removing the cables (steps 3,4 and 5) because it seems impossible to reconnect them.
Tom Wood - Yanıt Paylaş
Those are ZIF connectors—flip up the locking tab to release the cable, and you can remove/reinsert it freely.
Jeff Suovanen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 2,394
