Ana içeriğe geç
Kindle Paperwhite 2nd Generation Charging Port Replacement
Neye ihtiyacın var
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: adım 1, 2 resimden 1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Battery: adım 1, 2 resimden 2.
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
      • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 2, 2 resimden 1. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 2, 2 resimden 2.
      • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      FixBot'a Sor
      Yorum Ekle
    3. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 3, 1 resimden 1.
      • Carefully remove the mid-frame from the back cover.
      FixBot'a Sor
      Yorum Ekle
    4. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 4, 2 resimden 1. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 4, 2 resimden 2.
      • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
      FixBot'a Sor
      Yorum Ekle
    5. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 5, 1 resimden 1.
      • Carefully lift the battery and remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: adım 6, 2 resimden 1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Motherboard: adım 6, 2 resimden 2.
      • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
      • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
      FixBot'a Sor
      Yorum Ekle
    2. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 7, 2 resimden 1. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 7, 2 resimden 2.
      • Gently disconnect the zif connectors.
      • Some of these connectors are very thin and fragile, handle with care!
      FixBot'a Sor
      Yorum Ekle
    3. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 8, 3 resimden 1. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 8, 3 resimden 2. Kindle Paperwhite 2nd Generation Charging Port Replacement: adım 8, 3 resimden 3.
      • Gently remove the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Kindle Paperwhite 2nd Generation Charging Port Replacement, Charging Port: adım 9, 1 resimden 1.
      • The charging port is integrated in to the device motherboard.
      • From here, to fix a faulty port, either replace the entire motherboard, or carefully desolder the old port and solder a new one on in its place.
      • Check out the soldering guide for help.
      FixBot'a Sor
      Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Tyler Davis
2.007 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G2
4 Üyeler
25 adet Kılavuz yazıldı
10Kılavuz Yorumları
How to replace the USB port; replace the motherboard. Kind of a lame fix if you ask me. Whatever happened to soldering a new port on?
Sam Hardeman - Yanıt Paylaş
I have not done the fix yet but plan to replace the USB which appears to be a USB - micro B USB 2.0 Receptacle Connector 5 Position Surface Mount available at DigiKey. Is there any reason not to attempt this? I have microscope and soldering station. If not, where do you get the motherboard and how much is it?
Bill Smith - Yanıt Paylaş
Any updates? Did you run into any issues?
theend12212012 - Yanıt Paylaş
Démontage facile effectivement, mais les cinq microsoudures sur la carte mère sont impossibles à faire avec un simple fer à souder ! Il faut utiliser du matériel pour CMS (composant à montage en surface)…
Ceci dit mon problème vient effectivement de ces microsoudures. En appuyant simplement sur ces contacts mon Kindle s’est remis en marche ! Vive le travail mal fait à la construction…
telerando - Yanıt Paylaş
Getting the Kindle open and getting to the charging port was quite ‘easy’. In step 1 the top is stuck on with something like sticky back tape and the top can be gently pulled away from the tape.
Having got to the port I can not figure out how to replace it. This part does not seem to be easy, unless Step 9 is explained in much more detail. The contacts for the port seem to be incredibly small and I can’t figure out how they’re connected, or what part I need to order to replace the port.
Richard Garside - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 44
Son 30 gün: 252
Her zaman: 32,340
