Ana içeriğe geç
Kindle Paperwhite 2nd Generation Power Button Replacement
Neye ihtiyacın var
  1. Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: adım 1, 2 resimden 1. Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: adım 1, 2 resimden 2.
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Power Button Replacement: adım 2, 2 resimden 1. Kindle Paperwhite 2nd Generation Power Button Replacement: adım 2, 2 resimden 2.
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Power Button Replacement: adım 3, 1 resimden 1.
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Power Button Replacement: adım 4, 2 resimden 1. Kindle Paperwhite 2nd Generation Power Button Replacement: adım 4, 2 resimden 2.
    • Remove the power button carefully using a blue plastic opening tool, and replace with a functional unit.
    Can you tell me where to find a replacement button?
    Chris Lewis - Yanıt
    You ever found the button?
    Luka Buic -
    funny. I couldn’t locate a button either. I did however use an old Nintendo DS stylus sandpapered down. this would go into the power button hole and turn it on/off. hope it helps others!
    Darren Rutgers - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler Davis
1.697 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G2
4 Üyeler
17 adet Kılavuz yazıldı
5Kılavuz Yorumları
I have problems with my power button and this is very nice presentation, but I would like to know whether this button is an integral part of the back cover or can be purchased separately and, of course, where it can be purchased.
Thank you for answer and best regards,
Bojan
Bojan Briški - Yanıt
Seconding this: where exactly can I purchase the button?
Oren Leifer - Yanıt
Same for me…..where can I buy this button?
Rob Hoenstok - Yanıt
The power button must be part of an assembly that attaches to the main board in order for it to function. Where can I buy this assembly and not just the plastic button itself?
Roger Joseph
Roger joseph - Yanıt
This information is not useful unless the author tells us where to buy the power buttin.
Calvin Jordan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 75
Her zaman: 4,751
