KitchenAid KSM150PSER Bowl Screw Cap Replacement
Giriş
1. adıma gitRemoving the bowl screw cap is easy and doesn't take long. If the bowl doesn't stay in properly you might want to replace this part.
Neye ihtiyacın var
Using a #2 Phillips screwdriver, remove the three 13mm screws holding the bowl screw cap on by rotating them counterclockwise.
2 farklı kişi bu kılavuzu tamamladı.
