Giriş
This guide demonstrates how to replace the lens.
Neye ihtiyacın var
Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
Bu adımda kullanılan alet:Anti-Static Wrist Strap$7.95
Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
Remove all 7 screws:
Hold the camera firmly with one hand so that you can still see a screw.
Place the Philips 00(Found here)screwdriver into the screw.
Turn the screwdriver to the left until it is free.
Repeat for the remaining screws.
Use plastic opening tools to slightly open the side of the case.
Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
The first two are near the words "3X Optical Zoom".
The third is near the shutter button.
Open the battery door.
Press thumb firmly on battery door and slide it in the direction of the arrow.
Lift thumb allowing the door to swing open.
The battery door on my easyshare c813 is broken. How can i get a replacement door?
Locate the exposed portion of the LCD screen.
Use a wedge to free the LCD screen from the medal housing.
Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
Remove the 3 screws securing the lens to the camera.
Gently remove the lens from the remaining casing.
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Great, please I need help on my Kodak easyshare z1085 IS, other things is working, but always black can't see anything through the screen
