Ana içeriğe geç
Kodak Easyshare C813 Memory Card Replacement
    1. Kodak Easyshare C813 Memory Card Replacement, Memory Card: adım 1, 1 resimden 1.
      • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak Easyshare C813 Memory Card Replacement: adım 2, 3 resimden 1. Kodak Easyshare C813 Memory Card Replacement: adım 2, 3 resimden 2. Kodak Easyshare C813 Memory Card Replacement: adım 2, 3 resimden 3.
      • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
      FixBot'a Sor
      Yorum Ekle
    3. Kodak Easyshare C813 Memory Card Replacement: adım 3, 2 resimden 1. Kodak Easyshare C813 Memory Card Replacement: adım 3, 2 resimden 2.
      • Locate memory card slot and insert memory card by inserting the gold terminals first.
      • Apply pressure into you feel it lock into place.
      • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
      FixBot'a Sor
      Yorum Ekle
    4. Kodak Easyshare C813 Memory Card Replacement: adım 4, 2 resimden 1. Kodak Easyshare C813 Memory Card Replacement: adım 4, 2 resimden 2.
      • Return the battery door to its formerly closed position.
      FixBot'a Sor
      Yorum Ekle
    5. Kodak Easyshare C813 Memory Card Replacement: adım 5, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Samantha Murray
296 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G22
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 65
Her zaman: 11,058
