Ana içeriğe geç
Kodak Easyshare C813 Memory Card Replacement
  1. Kodak Easyshare C813 Memory Card Replacement, Memory Card: adım 1, 1 resimden 1.
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
  2. Kodak Easyshare C813 Memory Card Replacement: adım 2, 3 resimden 1. Kodak Easyshare C813 Memory Card Replacement: adım 2, 3 resimden 2. Kodak Easyshare C813 Memory Card Replacement: adım 2, 3 resimden 3.
    • Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
  3. Kodak Easyshare C813 Memory Card Replacement: adım 3, 2 resimden 1. Kodak Easyshare C813 Memory Card Replacement: adım 3, 2 resimden 2.
    • Locate memory card slot and insert memory card by inserting the gold terminals first.
    • Apply pressure into you feel it lock into place.
    • Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
  4. Kodak Easyshare C813 Memory Card Replacement: adım 4, 2 resimden 1. Kodak Easyshare C813 Memory Card Replacement: adım 4, 2 resimden 2.
    • Return the battery door to its formerly closed position.
  5. Kodak Easyshare C813 Memory Card Replacement: adım 5, 1 resimden 1.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Samantha Murray
269 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G22
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 10,000
