Ana içeriğe geç
Kodak S100 EF Flash Replacement
Neye ihtiyacın var
  1. Kodak S100 EF Flash Replacement, Front Cover: adım 1, 1 resimden 1.
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Flash Replacement: adım 2, 1 resimden 1.
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Flash Replacement: adım 3, 1 resimden 1.
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
  4. Kodak S100 EF Flash Replacement, Flash: adım 4, 1 resimden 1.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick
4 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 üyesi
CPSU-GARNER-S11S25G28
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 2,787
