Ana içeriğe geç
Kurio 7 Speaker Replacement
Neye ihtiyacın var
  1. Kurio 7 Speaker Replacement, Back Panel: adım 1, 3 resimden 1. Kurio 7 Speaker Replacement, Back Panel: adım 1, 3 resimden 2. Kurio 7 Speaker Replacement, Back Panel: adım 1, 3 resimden 3.
    • Begin by removing the rubber cover from the Kurio 7.
    FixBot'a Sor
    Yorum Ekle
  2. Kurio 7 Speaker Replacement: adım 2, 2 resimden 1. Kurio 7 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the four 30 mm Phillips #00 screws from the outer case.
    FixBot'a Sor
    Yorum Ekle
  3. Kurio 7 Speaker Replacement: adım 3, 2 resimden 1. Kurio 7 Speaker Replacement: adım 3, 2 resimden 2.
    • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
    • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Be careful not to break off the tabs that hold the front cover and the back cover together.
    FixBot'a Sor
    Yorum Ekle
  4. Kurio 7 Speaker Replacement: adım 4, 2 resimden 1. Kurio 7 Speaker Replacement: adım 4, 2 resimden 2.
    • Once all of the tabs are removed, the back cover should come off easily.
    • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
    FixBot'a Sor
    Yorum Ekle
  5. Kurio 7 Speaker Replacement, Kurio 7 Motherboard Removal Guide: adım 5, 2 resimden 1. Kurio 7 Speaker Replacement, Kurio 7 Motherboard Removal Guide: adım 5, 2 resimden 2.
    • Use a plastic credit card, or other thin object, to separate the battery from the screen.
    • Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
    • Carefully set the battery aside.
    FixBot'a Sor
    Yorum Ekle
  6. Kurio 7 Speaker Replacement: adım 6, 2 resimden 1. Kurio 7 Speaker Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
    FixBot'a Sor
    Yorum Ekle
  7. Kurio 7 Speaker Replacement: adım 7, 3 resimden 1. Kurio 7 Speaker Replacement: adım 7, 3 resimden 2. Kurio 7 Speaker Replacement: adım 7, 3 resimden 3.
    • Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
    • Pull the ribbon out of the mount.
    FixBot'a Sor
    Yorum Ekle
  8. Kurio 7 Speaker Replacement: adım 8, 1 resimden 1.
    • There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
    • Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
    • To remove the ribbon from the mount, follow the same steps in Step 3.
    FixBot'a Sor
    Yorum Ekle
  9. Kurio 7 Speaker Replacement: adım 9, 1 resimden 1.
    • Pull back the ribbons and put the battery near the bottom of the Kurio.
    • The motherboard is now removed so that other components can be worked on.
    FixBot'a Sor
    Yorum Ekle
  10. Kurio 7 Speaker Replacement, Speaker: adım 10, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Pull the wires off of the motherboard using the tweezers. The wires aren't soldered on well.
    • Before you do break the solder, check the wires connections. You may be able to just solder the wire if it is already broken off.
    FixBot'a Sor
    Yorum Ekle
  11. Kurio 7 Speaker Replacement: adım 11, 2 resimden 1. Kurio 7 Speaker Replacement: adım 11, 2 resimden 2.
    • Remove any hot glue residue holding the speaker in place by peeling it off using tweezers.
    FixBot'a Sor
    Yorum Ekle
  12. Kurio 7 Speaker Replacement: adım 12, 3 resimden 1. Kurio 7 Speaker Replacement: adım 12, 3 resimden 2. Kurio 7 Speaker Replacement: adım 12, 3 resimden 3.
    • Use the spudger to pry out the old speaker.
    • You have successfully removed the speaker!
    FixBot'a Sor
    Yorum Ekle
Sonuç
Solder in the new speaker. Refer to the soldering guide if you're unsure on how to solder. To reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Alex Powaser
331 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-36, Maness Spring 2014 Cal Poly, Team 12-36, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G36
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 2,369
