Ana içeriğe geç
Kurio Xtreme Battery Replacement
Neye ihtiyacın var
  1. Kurio Xtreme Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Battery Replacement: adım 2, 2 resimden 1. Kurio Xtreme Battery Replacement: adım 2, 2 resimden 2.
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Battery Replacement: adım 3, 3 resimden 1. Kurio Xtreme Battery Replacement: adım 3, 3 resimden 2. Kurio Xtreme Battery Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Battery Replacement, Battery: adım 4, 2 resimden 1. Kurio Xtreme Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Disconnect the black and red wires from the motherboard by soldering the ends that are connected to the motherboard.
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  5. Kurio Xtreme Battery Replacement: adım 5, 2 resimden 1. Kurio Xtreme Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
    • Be patient and gentle. The glue is strong and may take up to 30 seconds to remove.
    • Carefully lift the battery out of the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mallory Myers
1.190 İtibar
7 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-10, Williams Fall 2015 Baylor, Team 6-10, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G10
3 Üyeler
14 adet Kılavuz yazıldı
2 Yorum
j ai changé de batterie mais la batterie ne charge pas. est ce que c ets parce qu un des deux fils serait mal soudé?
j-p1955 - Yanıt
Does it have a certain battery or can a different battery fit?
Nikki Gilliard - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 3,956
