Ana içeriğe geç
Kyocera Hydro Life Charging Port Replacement
Neye ihtiyacın var
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: adım 1, 2 resimden 1. Kyocera Hydro Life Charging Port Replacement, Charging Port: adım 1, 2 resimden 2.
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: adım 2, 3 resimden 1. Kyocera Hydro Life Charging Port Replacement: adım 2, 3 resimden 2. Kyocera Hydro Life Charging Port Replacement: adım 2, 3 resimden 3.
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: adım 3, 1 resimden 1.
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: adım 4, 3 resimden 1. Kyocera Hydro Life Charging Port Replacement: adım 4, 3 resimden 2. Kyocera Hydro Life Charging Port Replacement: adım 4, 3 resimden 3.
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: adım 5, 3 resimden 1. Kyocera Hydro Life Charging Port Replacement: adım 5, 3 resimden 2. Kyocera Hydro Life Charging Port Replacement: adım 5, 3 resimden 3.
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: adım 6, 2 resimden 1. Kyocera Hydro Life Charging Port Replacement: adım 6, 2 resimden 2.
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: adım 7, 1 resimden 1.
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: adım 8, 1 resimden 1.
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: adım 9, 1 resimden 1.
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: adım 10, 1 resimden 1.
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,028
