Ana içeriğe geç
LERSTA Floor Lamp Screw Terminal Replacement
Neye ihtiyacın var
  1. LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: adım 1, 2 resimden 1. LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: adım 1, 2 resimden 2.
    • Unplug the lamp.
  2. LERSTA Floor Lamp Screw Terminal Replacement: adım 2, 1 resimden 1.
    • Rotate the bulb counterclockwise to remove the light bulb.
  3. LERSTA Floor Lamp Screw Terminal Replacement: adım 3, 1 resimden 1.
    • Rotate the lamp shade counterclockwise.
  4. LERSTA Floor Lamp Screw Terminal Replacement: adım 4, 1 resimden 1.
    • Take the three parts aside after dismantling the lamp shade.
  5. LERSTA Floor Lamp Screw Terminal Replacement: adım 5, 1 resimden 1.
    • Dismantle the lamp shaft by rotating it counterclockwise.
  6. LERSTA Floor Lamp Screw Terminal Replacement: adım 6, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 3 mm screws from the silver cover.
    • Pull down both the silver cover and the black screw terminal.
  7. LERSTA Floor Lamp Screw Terminal Replacement: adım 7, 1 resimden 1.
    • Separate the light bulb socket from the silver cover by pulling the silver metal hasp in right-downward direction towards the lamp shaft.
    • Exert force on the both left and right hand sides of the hasp and then pull the hasp downward.
  8. LERSTA Floor Lamp Screw Terminal Replacement: adım 8, 1 resimden 1.
    • Replace the old bulb socket with a newly-purchased one.
Sonuç
Replacing the screw terminal of the floor lamp is relatively easy, but be cautious to deal with the step of the substitution of the light socket.
[deleted]
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 20
Her zaman: 1,165
