Ana içeriğe geç
LG 305C Touch Screen Assembly Replacement
Neye ihtiyacın var
  1. LG 305C  Touch Screen Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
  2. LG 305C  Touch Screen Assembly Replacement: adım 2, 1 resimden 1.
    • Pry the battery out of the device with a plastic opening tool opposite from the plastic pieces keeping it in place and remove it gently in order to ensure that you don’t damage it.
  3. LG 305C  Touch Screen Assembly Replacement, Touch Screen: adım 3, 2 resimden 1. LG 305C  Touch Screen Assembly Replacement, Touch Screen: adım 3, 2 resimden 2.
    • Unscrew the back of your device and on the white strip underneath, it should read LG 305C.
    • Note: If it does not read LG305C as the model number, please refer to another guide in order to replace your screen.
  4. LG 305C  Touch Screen Assembly Replacement, SD Card Removal: adım 4, 1 resimden 1.
  5. LG 305C  Touch Screen Assembly Replacement: adım 5, 3 resimden 1. LG 305C  Touch Screen Assembly Replacement: adım 5, 3 resimden 2. LG 305C  Touch Screen Assembly Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the seven screws that are located along the edges of the device.
  6. LG 305C  Touch Screen Assembly Replacement: adım 6, 2 resimden 1. LG 305C  Touch Screen Assembly Replacement: adım 6, 2 resimden 2.
    • Using your plastic pry tool, pry along the edges of plastic side of the screen to loosen and separate the first screen layer.
    • As shown in Picture 2, push in the notch along the edge of the charging port.
  7. LG 305C  Touch Screen Assembly Replacement: adım 7, 3 resimden 1. LG 305C  Touch Screen Assembly Replacement: adım 7, 3 resimden 2. LG 305C  Touch Screen Assembly Replacement: adım 7, 3 resimden 3.
    • Remove the front end of the screen by gently swinging it out from its notched in position as shown.
  8. LG 305C  Touch Screen Assembly Replacement: adım 8, 2 resimden 1. LG 305C  Touch Screen Assembly Replacement: adım 8, 2 resimden 2.
    • Gently pry off the touch screen connection attached to the motherboard with your finger.
    • Once detached, gently separate the motherboard and plastic screen mold. It should look the same as Picture 2
Sonuç
To reassemble your device, follow the steps in reverse. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
alex Benitez
124 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 468
